Model 80 Compact alignment
By ham fisted I was more meaning that what they touched was obvious rather than incorrect. There is a big difference between the original soldered connections and later repairs. The connections on the transformers look original. I found a lot of out of spec resistors and caps but no miswires. It apparently can be aligned using a 460 khz signal generator so that is correct in that the procedures work. The problem is my annoying habit of digging a little deeper.
The case was quite likely refinished at some time. However, it doesn't look bad and I don't think we will refinish it at this point. If it had been sprayed pink or had that fake wood grain brush on stuff we obviously would redo it.
keithw
Model 80 Compact alignment - by barshnik - 06-25-2013, 03:31 PM
RE: Model 80 Compact alignment - by keithw - 06-25-2013, 03:53 PM
RE: Model 80 Compact alignment - by 7estatdef - 06-25-2013, 05:57 PM
RE: Model 80 Compact alignment - by keithw - 06-25-2013, 06:37 PM
RE: Model 80 Compact alignment - by 7estatdef - 06-25-2013, 09:36 PM
RE: Model 80 Compact alignment - by keithw - 06-25-2013, 11:05 PM
RE: Model 80 Compact alignment - by BrendaAnnD - 06-26-2013, 12:11 AM
RE: Model 80 Compact alignment - by keithw - 06-26-2013, 12:26 AM
RE: Model 80 Compact alignment - by BrendaAnnD - 06-26-2013, 01:15 AM
RE: Model 80 Compact alignment - by Arran - 06-26-2013, 01:38 AM
RE: Model 80 Compact alignment - by keithw - 06-26-2013, 08:49 AM
RE: Model 80 Compact alignment - by Ron Ramirez - 06-26-2013, 10:44 AM
RE: Model 80 Compact alignment - by keithw - 06-26-2013, 11:19 AM
RE: Model 80 Compact alignment - by Ron Ramirez - 06-26-2013, 11:47 AM
RE: Model 80 Compact alignment - by keithw - 06-26-2013, 12:17 PM
RE: Model 80 Compact alignment - by Ron Ramirez - 06-26-2013, 12:27 PM
RE: Model 80 Compact alignment - by Mondial - 06-26-2013, 01:48 PM
RE: Model 80 Compact alignment - by 7estatdef - 06-26-2013, 06:05 PM
RE: Model 80 Compact alignment - by Ron Ramirez - 06-26-2013, 06:55 PM
RE: Model 80 Compact alignment - by keithw - 06-26-2013, 09:40 PM
RE: Model 80 Compact alignment - by barshnik - 06-26-2013, 10:35 PM
RE: Model 80 Compact alignment - by keithw - 06-27-2013, 12:12 AM
RE: Model 80 Compact alignment - by Ron Ramirez - 06-27-2013, 05:09 AM
RE: Model 80 Compact alignment - by morzh - 06-27-2013, 09:23 AM
RE: Model 80 Compact alignment - by keithw - 06-27-2013, 09:33 AM
RE: Model 80 Compact alignment - by barshnik - 06-27-2013, 10:30 PM
RE: Model 80 Compact alignment - by codefox1 - 06-28-2013, 08:06 AM
RE: Model 80 Compact alignment - by 7estatdef - 06-29-2013, 06:26 PM
RE: Model 80 Compact alignment - by keithw - 07-16-2013, 10:53 PM
There are currently 10548 online users. [Complete List]
» 3 Member(s) | 10545 Guest(s)
