Veneer on 16B Tombstone?
It's definitely a piece of veneer that is missing. I'll try and get a closer shot tonight and post it.
- Geoff
Veneer on 16B Tombstone? - by Geoff - 06-26-2013, 06:39 PM
RE: Veneer on 16B Tombstone? - by Arran - 06-26-2013, 07:55 PM
RE: Veneer on 16B Tombstone? - by Geoff - 06-26-2013, 08:32 PM
RE: Veneer on 16B Tombstone? - by Art Hoch - 06-27-2013, 10:10 AM
RE: Veneer on 16B Tombstone? - by Geoff - 06-27-2013, 09:56 PM
RE: Veneer on 16B Tombstone? - by Arran - 06-28-2013, 02:22 AM
RE: Veneer on 16B Tombstone? - by Art Hoch - 06-28-2013, 06:19 PM
There are currently 10203 online users. [Complete List]
» 1 Member(s) | 10202 Guest(s)
