Can you offer a solution; American Bosch chassis
I wonder if the drive belt was actually a phosphor bronze band like the ones used on early Atwater Kent radios. Is there a hole in the drive surface of the pulley to fasten the belt with a screw? There seems to be some sort of hole visible in the photo.
Here is a source for the Atwater Kent belts. Perhaps one of these could be modified or used for the purpose?
http://www.adamsradio.com/page13.html
There are currently 7771 online users. [Complete List]
» 2 Member(s) | 7769 Guest(s)
