Flex resistors ?
So long as you can sub a good modern carbon or wirewond of the same value and wattage for a failed component, good. Try to find out why original failed first. If analysis shows part of a voltage divider, then the hunt is on.........
Flex resistors ? - by Eric - 06-26-2013, 12:07 PM
RE: Flex resistors ? - by Mondial - 06-26-2013, 02:24 PM
RE: Flex resistors ? - by Eric - 06-26-2013, 05:42 PM
RE: Flex resistors ? - by codefox1 - 06-27-2013, 05:03 PM
RE: Flex resistors ? - by Arran - 06-28-2013, 02:05 AM
RE: Flex resistors ? - by Eric - 06-28-2013, 08:37 AM
