Veneer on 16B Tombstone?
It looks like it may be maple veneer, but it's difficult to know without stripping it, in short it's a bland and blond hardwood that they used. I would just get some maple, birch, or beech veneer and patch the damaged section with a narrow strip running from top to bottom parallel to the grain of the existing veneer.
Veneer on 16B Tombstone? - by Geoff - 06-26-2013, 06:39 PM
RE: Veneer on 16B Tombstone? - by Arran - 06-26-2013, 07:55 PM
RE: Veneer on 16B Tombstone? - by Geoff - 06-26-2013, 08:32 PM
RE: Veneer on 16B Tombstone? - by Art Hoch - 06-27-2013, 10:10 AM
RE: Veneer on 16B Tombstone? - by Geoff - 06-27-2013, 09:56 PM
RE: Veneer on 16B Tombstone? - by Arran - 06-28-2013, 02:22 AM
RE: Veneer on 16B Tombstone? - by Art Hoch - 06-28-2013, 06:19 PM
There are currently 10175 online users. [Complete List]
» 1 Member(s) | 10174 Guest(s)
