Can you offer a solution; American Bosch chassis
don't have one to look at, but any mechanism of yore that uses a dial string has a spring to allow for eventual stretching. Several turns of the string were usually needed on the small turning shaft, and yes, roughing it up a bit with fine abrasive after removing all grease helps a lot with traction.
There are currently 5207 online users. [Complete List]
» 5 Member(s) | 5202 Guest(s)
AvatarAvatarAvatarAvatar
