Messed up Philco 90
#35
Hi All;
I Think that Bob is doing the right (correct) thing for Him.. I would do it a little bit differently, but I am not Bob.. I would Reverse-Engineer or make a Schematic of what is there, If for no other reason than to find out what is there.. And then once I knew what the circuit looked like depending on what I found I would either make it work with what was there and finish what would be needed to make it into a working radio.. Or I would completely convert it back to being a Philco 90.. Keep up the good work Bob..
THANK YOU Marty
Messed up Philco 90 - by Bob Andersen - 06-06-2013, 04:17 PM
RE: Messed up Philco 90 - by Bob Andersen - 06-06-2013, 04:26 PM
RE: Messed up Philco 90 - by Art Hoch - 06-06-2013, 05:29 PM
RE: Messed up Philco 90 - by Mondial - 06-06-2013, 06:25 PM
RE: Messed up Philco 90 - by morzh - 06-06-2013, 06:57 PM
RE: Messed up Philco 90 - by Bill Kinghorn - 06-06-2013, 07:02 PM
RE: Messed up Philco 90 - by Bill Kinghorn - 06-06-2013, 07:05 PM
RE: Messed up Philco 90 - by Bob Andersen - 06-06-2013, 08:20 PM
RE: Messed up Philco 90 - by Mondial - 06-06-2013, 08:48 PM
RE: Messed up Philco 90 - by GarySP - 06-06-2013, 09:14 PM
RE: Messed up Philco 90 - by Bill Kinghorn - 06-06-2013, 11:30 PM
RE: Messed up Philco 90 - by morzh - 06-06-2013, 11:34 PM
RE: Messed up Philco 90 - by Bob Andersen - 06-07-2013, 12:01 AM
RE: Messed up Philco 90 - by morzh - 06-07-2013, 12:27 AM
RE: Messed up Philco 90 - by Bob Andersen - 06-07-2013, 12:39 AM
RE: Messed up Philco 90 - by Arran - 06-07-2013, 03:22 AM
RE: Messed up Philco 90 - by Philco281989 - 06-09-2013, 12:07 PM
RE: Messed up Philco 90 - by Bob Andersen - 06-09-2013, 02:02 PM
RE: Messed up Philco 90 - by wa2ise - 06-11-2013, 09:45 PM
RE: Messed up Philco 90 - by Bob Andersen - 06-23-2013, 04:05 PM
RE: Messed up Philco 90 - by morzh - 06-23-2013, 07:29 PM
RE: Messed up Philco 90 - by Bob Andersen - 06-23-2013, 09:35 PM
RE: Messed up Philco 90 - by Arran - 06-23-2013, 09:44 PM
RE: Messed up Philco 90 - by Bob Andersen - 06-23-2013, 10:22 PM
RE: Messed up Philco 90 - by Arran - 06-24-2013, 12:08 AM
RE: Messed up Philco 90 - by wa2ise - 06-25-2013, 09:20 PM
RE: Messed up Philco 90 - by Arran - 06-25-2013, 09:35 PM
RE: Messed up Philco 90 - by morzh - 06-25-2013, 10:39 PM
RE: Messed up Philco 90 - by AI2V - 06-27-2013, 10:05 AM
RE: Messed up Philco 90 - by Bob Andersen - 06-27-2013, 11:27 AM
RE: Messed up Philco 90 - by Electrothaumaturgist - 06-27-2013, 11:29 AM
RE: Messed up Philco 90 - by Ron Ramirez - 06-27-2013, 04:42 PM
RE: Messed up Philco 90 - by Arran - 06-28-2013, 01:55 AM
RE: Messed up Philco 90 - by Eliot Ness - 06-28-2013, 08:25 AM
RE: Messed up Philco 90 - by marty - 06-28-2013, 09:29 AM
RE: Messed up Philco 90 - by Bob Andersen - 06-28-2013, 12:33 PM
RE: Messed up Philco 90 - by morzh - 07-05-2013, 10:10 PM
Philco 91 Tuning Condenser
There are currently 9236 online users. [Complete List]
» 2 Member(s) | 9234 Guest(s)
