How many Philco 38-116 radios are out there?
I did remove the RF deck and recapped it; I also had to clear a short on the RF section of the bandswitch.
John, does your radio go dead on the low end of the BC band? A weak 6A8 can cause that problem.
Tim KA3JRT
RE: How many Philco 38-116 radios are out there? - by Tim Tress - 06-28-2013, 02:14 PM
Philco 91 Tuning Condenser
There are currently 4242 online users. [Complete List]
» 1 Member(s) | 4241 Guest(s)
