  • 1 Vote(s) - 5 Average
Another Phactory Phranken-Philco?
I saw this at the MARC Extravaganza auction this afternoon:
[Image: http://www.philcoradio.com/images/phorum...0002-8.jpg]
[Image: http://www.philcoradio.com/images/phorum...0004-5.jpg]
Big deal, another Philco grandfather clock, right?
Look closer:
[Image: http://www.philcoradio.com/images/phorum...0003-7.jpg]
It has a Philco 89 chassis inside - and from the looks of the front panel, it appears that it may have been made for use with this chassis!
I ended up with it - paid more than I wanted to for it, but this will give me the opportunity to examine it more closely later.
I knew Philco put 52 chassis inside these grandfather clock cabinets to use up excess stock, but I've never heard of, nor seen, an 89 in a grandfather clock cabinet...
Another Phactory Phranken-Philco? - by Ron Ramirez - 06-28-2013, 06:42 PM
RE: Another Phactory Phranken-Philco? - by Arran - 06-28-2013, 08:24 PM
RE: Another Phactory Phranken-Philco? - by morzh - 06-30-2013, 04:16 PM
RE: Another Phactory Phranken-Philco? - by Arran - 07-01-2013, 02:54 AM
RE: Another Phactory Phranken-Philco? - by Arran - 07-02-2013, 09:20 PM
Philco 91 Tuning Condenser
