1948 Philco album length phonograph
Hi All;
It looks Fantastic !!!! Does it plug into a Philco Radio to be able to play Or Does it have its own Amp and Speaker ??
RE: 1948 Philco album length phonograph - by marty - 06-29-2013, 10:23 AM
Philco 91 Tuning Condenser
