1948 Philco album length phonograph
Oh these....I did not even know they make them. These are truly POC ones but then I do not understand why anyone would buy those. I thought they put only CD players and FM radios inside.
RE: 1948 Philco album length phonograph - by morzh - 06-30-2013, 10:44 AM
There are currently 9041 online users. [Complete List]
» 1 Member(s) | 9040 Guest(s)
