1948 Philco album length phonograph
I have paid 1$ plus shipping trough the canadian borders - 99 cents initial bid on an AS-IS ebay auction. Turns out everything works but the CD player; i've rerouted it to an aux-in jack for MP3 players.
NostalgiaRadioTime, that connector is almost identical to what was between the record-changer and radio chassis on my 47-1230 - I guess they were pretty much standard already. It is the female connector that I found more puzzling.
Here's a picture of mine.
-Mars
RE: 1948 Philco album length phonograph - by Marsupial - 07-01-2013, 01:18 AM
Philco 91 Tuning Condenser
There are currently 9371 online users. [Complete List]
» 1 Member(s) | 9370 Guest(s)
