41-250 oscillator problems
The dual cap marked 21 and 21A should be replaced. It looks like a mica cap but in fact is paper. It has been bad in most of the radios of this design that I have refurbed.
Does the oscillator work with the pushbuttons?
That might give a clue.
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
[No subject] - by Terry Judkins - 02-05-2008, 05:43 PM
[No subject] - by Guest - 02-05-2008, 07:53 PM
[No subject] - by electroubleshooter - 02-05-2008, 09:17 PM
[No subject] - by electroubleshooter - 02-05-2008, 09:18 PM
[No subject] - by Terry Judkins - 02-05-2008, 09:31 PM
[No subject] - by electroubleshooter - 02-05-2008, 11:02 PM
[No subject] - by justlrnin - 02-06-2008, 12:15 AM
[No subject] - by Terry Judkins - 02-06-2008, 11:39 AM
There are currently 10445 online users. [Complete List]
» 2 Member(s) | 10443 Guest(s)
