Anybody know what make this radio is?
Hi there and greetings from The Netherlands - Europe
Just this week I bought the same radio. Orig. the radio was bought by the former owner in an antique shop about 20 years ago.
The radio plays but unfort not all the knobs are orginal. Als the grill cloth is not the same as it use to be back then
Is it difficult to find parts or a manual
Thx and keep up the good (collectors) work
Mario
RE: Anybody know what make this radio is? - by 4allofyou - 07-01-2013, 04:47 PM
There are currently 7733 online users. [Complete List]
» 2 Member(s) | 7731 Guest(s)
