Philco 46-1203, radio doesn't work.
Maybe someone who's worked on one of these can shed some light on the volume control. In looking at it again, it almost appears that the volume control is similar to a balance control on a stereo with the exception that the center position effectively shunts the signal being sent to the amplifier section. I'm guessing that turning clockwise from center increases the volume of either the radio or phono, counterclockwise from center the other?
Philco 46-1203, radio doesn't work. - by Guest - 02-04-2008, 09:47 PM
[No subject] - by TonyJSenior - 02-05-2008, 06:07 PM
[No subject] - by TonyJSenior - 02-05-2008, 07:48 PM
[No subject] - by Guest - 02-06-2008, 04:28 AM
[No subject] - by TonyJSenior - 02-06-2008, 08:26 AM
[No subject] - by Guest - 02-06-2008, 01:14 PM
[No subject] - by TonyJSenior - 02-06-2008, 01:23 PM
46-1203 volume control - by Guest - 06-19-2008, 11:44 AM
46-1203 volume control - by Guest - 06-19-2008, 11:59 AM
[No subject] - by gary rabbitt - 06-20-2008, 02:06 PM
Re: Philco 46-1203, radio doesn't work. - by Guest - 07-19-2008, 03:38 AM
Re: 46-1203 volume control - by Guest - 07-19-2008, 03:43 AM
philco 46-1203 - by Guest - 08-30-2008, 12:03 AM
[No subject] - by BDM - 08-30-2008, 01:13 AM
Re: Philco 46-1203, radio doesn't work. - by Guest - 09-04-2008, 12:14 AM
Re: Philco 46-1203, radio doesn't work. - by Guest - 09-04-2008, 02:09 AM
There are currently 9750 online users. [Complete List]
» 2 Member(s) | 9748 Guest(s)
