Newbie, Philco H865
Excited. The shop I took it to found a cartridge and needle for it! He'll order it tomorrow.
Newbie, Philco H865 - by RayenTiger - 06-23-2013, 09:19 PM
RE: Newbie, Philco H865 - by Don Lind - 06-24-2013, 11:45 PM
RE: Newbie, Philco H865 - by RayenTiger - 06-25-2013, 06:56 AM
RE: Newbie, Philco H865 - by RayenTiger - 06-25-2013, 07:16 AM
RE: Newbie, Philco H865 - by Don Lind - 06-25-2013, 02:29 PM
RE: Newbie, Philco H865 - by RayenTiger - 07-01-2013, 06:39 PM
Philco 91 Tuning Condenser
There are currently 9688 online users. [Complete List]
» 1 Member(s) | 9687 Guest(s)
