Found an Atwater-Kent 44
I stumbled upon this today during a spur of the moment visit to a local antique shop. It is all complete, has usable tubes and I snatched it up for $65. I actually had it working a bit on reduced power and pulled in some stations before the power supply box started to gurgle and make nasty smells from the tar. So, it will need some work, but it's the most complete AK table unit of this type I have ever run across, and the cheapest when you count all that is there.
Found an Atwater-Kent 44 - by Jayce - 07-01-2013, 10:53 PM
RE: Found an Atwater-Kent 44 - by BrendaAnnD - 07-02-2013, 02:57 AM
RE: Found an Atwater-Kent 44 - by TA Forbes - 07-02-2013, 09:15 AM
RE: Found an Atwater-Kent 44 - by Jayce - 07-02-2013, 05:02 PM
There are currently 7094 online users. [Complete List]
» 1 Member(s) | 7093 Guest(s)
