  • 1 Vote(s) - 5 Average
Another Phactory Phranken-Philco?
Interesting that they used the later four knob model 89 versus the earlier three knob model.
RE: Another Phactory Phranken-Philco? - by Arran - 06-28-2013, 08:24 PM
RE: Another Phactory Phranken-Philco? - by morzh - 06-30-2013, 04:16 PM
RE: Another Phactory Phranken-Philco? - by Arran - 07-01-2013, 02:54 AM
RE: Another Phactory Phranken-Philco? - by TA Forbes - 07-02-2013, 08:47 AM
RE: Another Phactory Phranken-Philco? - by Arran - 07-02-2013, 09:20 PM
Philco 91 Tuning Condenser
There are currently 8938 online users. [Complete List]
» 2 Member(s) | 8936 Guest(s)
