Philco Model 37-61 Owners Manual
does anyone still have this manual? i just got one and i am going to restore it. i would like the manual for it.. any help would be appreciated.
Gary
Philco Model 37-61 Owners Manual - by Guest - 05-29-2010, 06:41 PM
RE: Philco Model 37-61 Owners Manual - by kakarrot62 - 07-02-2013, 02:14 PM
Re: Philco Model 37-61 Owners Manual - by Guest - 05-30-2010, 12:50 PM
Re: Philco Model 37-61 Owners Manual - by Rguess - 11-21-2010, 11:37 PM
Philco 91 Tuning Condenser
