Philco Model 37-61 Owners Manual
Email Chuck Schwark who posted above. (use the EMAIL button on his post) Its likely he retained a copy. He can also send you all the schematic and servicing information in high quality so its very readable for a very modest charge.
Philco Model 37-61 Owners Manual - by Guest - 05-29-2010, 06:41 PM
RE: Philco Model 37-61 Owners Manual - by klondike98 - 07-02-2013, 04:27 PM
Re: Philco Model 37-61 Owners Manual - by Guest - 05-30-2010, 12:50 PM
Re: Philco Model 37-61 Owners Manual - by Rguess - 11-21-2010, 11:37 PM
Philco 91 Tuning Condenser
There are currently 9246 online users. [Complete List]
» 1 Member(s) | 9245 Guest(s)
