Troubleshooting a Philco 47-1230
Use the solution Arran suggests, but don't use steel wool. I use 3M Scrunge pads (the kind that look like green steel wool ). Mr Clean dirt erasers work well too. As for drying afterwards, another option is preheating your oven to about 200F. Put the chassis in, turn off the oven, and leave it overnight. The dry heat will dry it very well. Take care, Gary.
Troubleshooting a Philco 47-1230 - by Warren - 06-17-2013, 11:37 PM
RE: Troubleshooting a Philco 47-1230 - by Mondial - 06-18-2013, 07:36 AM
RE: Troubleshooting a Philco 47-1230 - by Warren - 06-19-2013, 12:10 AM
RE: Troubleshooting a Philco 47-1230 - by Warren - 06-19-2013, 01:40 PM
RE: Troubleshooting a Philco 47-1230 - by Warren - 07-04-2013, 06:03 PM
RE: Troubleshooting a Philco 47-1230 - by Mondial - 07-04-2013, 06:17 PM
RE: Troubleshooting a Philco 47-1230 - by Warren - 07-04-2013, 06:57 PM
RE: Troubleshooting a Philco 47-1230 - by Arran - 07-05-2013, 12:42 AM
RE: Troubleshooting a Philco 47-1230 - by Warren - 07-05-2013, 12:57 AM
RE: Troubleshooting a Philco 47-1230 - by GarySP - 07-05-2013, 03:32 PM
RE: Troubleshooting a Philco 47-1230 - by Arran - 07-05-2013, 09:18 PM
RE: Troubleshooting a Philco 47-1230 - by Warren - 07-05-2013, 10:48 PM
RE: Troubleshooting a Philco 47-1230 - by Mondial - 07-05-2013, 10:59 PM
RE: Troubleshooting a Philco 47-1230 - by Warren - 07-06-2013, 12:11 AM
RE: Troubleshooting a Philco 47-1230 - by GarySP - 07-06-2013, 10:31 AM
Philco 91 Tuning Condenser
There are currently 8983 online users. [Complete List]
» 2 Member(s) | 8981 Guest(s)
