Barn Fresh 90 Highboy
You are right about the 71 being a superb performer. I have a 71X that has a slanted sound board and looks like the 91X cabinet. I redid that one and it is also a great performer. I listen to it almost every day.
I have an 18H that I have to redo one of these days also. I looks kind of like your 90.
Don
Barn Fresh 90 Highboy - by Ron Ramirez - 02-06-2008, 11:51 PM
[No subject] - by Ron Ramirez - 02-09-2008, 01:22 AM
[No subject] - by Guest - 02-09-2008, 11:54 AM
[No subject] - by Ron Ramirez - 02-09-2008, 02:34 PM
[No subject] - by Guest - 02-09-2008, 05:01 PM
[No subject] - by PhilcoPhil - 02-09-2008, 09:05 PM
[No subject] - by Ron Ramirez - 02-23-2008, 11:39 PM
[No subject] - by Texasrocker - 02-26-2008, 11:43 PM
Re: Barn Fresh 90 Highboy - by n9vu - 02-29-2008, 09:49 AM
[No subject] - by Ron Ramirez - 02-29-2008, 10:27 AM
[No subject] - by etech - 03-16-2008, 09:54 PM
[No subject] - by BDM - 03-16-2008, 10:33 PM
[No subject] - by Ron Ramirez - 03-16-2008, 10:41 PM
[No subject] - by etech - 03-17-2008, 04:06 PM
Philco 91 Tuning Condenser
