It followed me home....is it a keeper???
Unless 10 bucks is something that you stole from your children's mouths (in which case you should not buy any radios at all) 10 bucks today is the same as free. It is a token of "I acknowledge you gave me the radio and I thank you". Sort of like the original owner of Edison's house sold it to the company he was embezzling money from for $1.
So....yeah, if nothing else is good other than 2-3 tubes even then it's worth it.
RE: It followed me home....is it a keeper??? - by morzh - 07-05-2013, 09:09 PM
There are currently 7645 online users. [Complete List]
» 3 Member(s) | 7642 Guest(s)
