Philco 39-35.......opinions!
It's one of the console versions of a Philco 39-30, it has six tubes so it's a pretty average set. If you have a limited amount of space I think I would probably pass on it unless you really like the thing. If there is a console and a table set the share the same chassis I tend towards the table versions.
Philco 39-35.......opinions! - by 462ron - 07-06-2013, 08:20 PM
RE: Philco 39-35.......opinions! - by Arran - 07-06-2013, 09:25 PM
RE: Philco 39-35.......opinions! - by Ron Ramirez - 07-06-2013, 09:54 PM
RE: Philco 39-35.......opinions! - by 462ron - 07-07-2013, 11:43 AM
RE: Philco 39-35.......opinions! - by shaler78 - 07-07-2013, 01:59 PM
Philco 91 Tuning Condenser
