Philco 39-35.......opinions!
Thanks Arran and Ron. That is what I was thinking. No RF amp and only one stage
of IF so I thought it would only be average plus a single ended audio output. What a pity though because the cabinet is beautiful. Oh we'll, I'll keep hoping for that 37 or
38-116 someday.
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Philco 39-35.......opinions! - by 462ron - 07-06-2013, 08:20 PM
RE: Philco 39-35.......opinions! - by Arran - 07-06-2013, 09:25 PM
RE: Philco 39-35.......opinions! - by Ron Ramirez - 07-06-2013, 09:54 PM
RE: Philco 39-35.......opinions! - by 462ron - 07-07-2013, 11:43 AM
RE: Philco 39-35.......opinions! - by shaler78 - 07-07-2013, 01:59 PM
Philco 91 Tuning Condenser
