80 Jr Troubleshooting- B+ measurements
Need some help please.  Recapped an 80Jr that was playing originally (at least it pulled in one station when I went to pick it up but I asked the seller to turn it off as soon as I got there ).  Also replaced out of spec dogbone resistors.  When I power it up now, it is motorboating all across the tuning span.  Some voltages:
[Image: https://www.dropbox.com/s/jnru9hgema6p6j....jpg?raw=1]  "CORRECTED TABLE"
The strange thing is when I put a test lead on plate of the Det-Osc tube, all the motorboating stops (although I can not tune in any stations).  If I put the test lead on the cathode of the Det-Osc tube, it still motorboats, except when I tune it to one strong station we have, which then comes in clearly.  Don't have a tube tester but since it was playing originally I'm assuming they are still OK.  Any thoughts on what to try next.   Thanks!
80 Jr Troubleshooting- B+ measurements - by klondike98 - 07-07-2013, 02:00 PM
RE: 80 Jr Troubleshooting advice - by Mondial - 07-07-2013, 02:43 PM
RE: 80 Jr Troubleshooting advice - by morzh - 07-07-2013, 03:31 PM
RE: 80 Jr Troubleshooting advice - by klondike98 - 07-07-2013, 06:35 PM
RE: 80 Jr Troubleshooting advice - by 7estatdef - 07-07-2013, 08:45 PM
RE: 80 Jr Troubleshooting advice - by klondike98 - 07-07-2013, 09:22 PM
RE: 80 Jr Troubleshooting advice - by klondike98 - 07-08-2013, 04:37 PM
RE: 80 Jr Troubleshooting advice - by 7estatdef - 07-08-2013, 06:29 PM
RE: 80 Jr Troubleshooting advice - by klondike98 - 07-10-2013, 08:48 AM
RE: 80 Jr Troubleshooting advice - by 7estatdef - 07-10-2013, 07:36 PM
RE: 80 Jr Troubleshooting advice - by klondike98 - 07-11-2013, 09:09 AM
RE: 80 Jr Troubleshooting-Solved! - by Mondial - 07-11-2013, 09:28 AM
RE: 80 Jr Troubleshooting-Solved! - by morzh - 07-11-2013, 11:14 AM
RE: 80 Jr Troubleshooting-Solved! - by klondike98 - 07-11-2013, 06:35 PM
RE: 80 Jr Troubleshooting-Solved! - by 7estatdef - 07-11-2013, 08:32 PM
RE: 80 Jr Troubleshooting-Solved! - by klondike98 - 07-12-2013, 02:33 PM
There are currently 3447 online users. [Complete List]
» 2 Member(s) | 3445 Guest(s)
