80 Jr Troubleshooting- B+ measurements
Thanks Mondial...I checked my measurement and realized I made a typo. I've corrected the table in the original post. The value was 207 not 107v.
Thanks Morzh...the regen adjustment does not correct the motorboating. I can adjust clockwise until I get the expected squeal but lowering the regen well below where it should be does not remove the motorboating.
RE: 80 Jr Troubleshooting advice - by Mondial - 07-07-2013, 02:43 PM
RE: 80 Jr Troubleshooting advice - by morzh - 07-07-2013, 03:31 PM
RE: 80 Jr Troubleshooting advice - by klondike98 - 07-07-2013, 06:35 PM
RE: 80 Jr Troubleshooting advice - by 7estatdef - 07-07-2013, 08:45 PM
RE: 80 Jr Troubleshooting advice - by klondike98 - 07-07-2013, 09:22 PM
RE: 80 Jr Troubleshooting advice - by klondike98 - 07-08-2013, 04:37 PM
RE: 80 Jr Troubleshooting advice - by 7estatdef - 07-08-2013, 06:29 PM
RE: 80 Jr Troubleshooting advice - by klondike98 - 07-10-2013, 08:48 AM
RE: 80 Jr Troubleshooting advice - by 7estatdef - 07-10-2013, 07:36 PM
RE: 80 Jr Troubleshooting advice - by klondike98 - 07-11-2013, 09:09 AM
RE: 80 Jr Troubleshooting-Solved! - by Mondial - 07-11-2013, 09:28 AM
RE: 80 Jr Troubleshooting-Solved! - by morzh - 07-11-2013, 11:14 AM
RE: 80 Jr Troubleshooting-Solved! - by klondike98 - 07-11-2013, 06:35 PM
RE: 80 Jr Troubleshooting-Solved! - by 7estatdef - 07-11-2013, 08:32 PM
RE: 80 Jr Troubleshooting-Solved! - by klondike98 - 07-12-2013, 02:33 PM
There are currently 6058 online users. [Complete List]
» 1 Member(s) | 6057 Guest(s)
