Model 60 Rectifier Circuit
Hi Bob
Not sure what diagram you are using? Can you post a link to it? Typically K stands for cathode in regards to tube connections. You aren't going to find any HV there, look for P would be the plate. That's where the HV should be.
Model 60 Rectifier Circuit - by Bob - 07-09-2013, 08:03 PM
RE: Model 60 Rectifier Circuit - by Arran - 07-09-2013, 08:46 PM
RE: Model 60 Rectifier Circuit - by 7estatdef - 07-09-2013, 08:52 PM
RE: Model 60 Rectifier Circuit - by BrendaAnnD - 07-10-2013, 02:45 AM
RE: Model 60 Rectifier Circuit - by Bob - 07-10-2013, 08:20 PM
RE: Model 60 Rectifier Circuit - by Bob - 07-14-2013, 08:19 PM
There are currently 8626 online users. [Complete List]
» 1 Member(s) | 8625 Guest(s)
