Model 65 alignment
Typically the alignment of a TRF set with screen grid tubes is to adjust the trimmers at 1500kc. Do all of your coils have good continuity??
Model 65 alignment - by tab10672 - 07-09-2013, 11:29 AM
RE: Model 65 alignment - by 7estatdef - 07-09-2013, 09:03 PM
RE: Model 65 alignment - by tab10672 - 07-09-2013, 11:05 PM
RE: Model 65 alignment - by 7estatdef - 07-10-2013, 07:18 AM
RE: Model 65 alignment - by tab10672 - 07-10-2013, 11:18 PM
RE: Model 65 alignment - by BrendaAnnD - 07-10-2013, 11:24 PM
RE: Model 65 alignment - by tab10672 - 07-10-2013, 11:35 PM
RE: Model 65 alignment - by BrendaAnnD - 07-11-2013, 12:41 AM
RE: Model 65 alignment - by Ron Ramirez - 07-11-2013, 05:47 AM
RE: Model 65 alignment - by tab10672 - 07-11-2013, 03:04 PM
