Grill frame for 89
I *think* it will, it looks right as the 89 speaker backing board looks the same. You may have to trim a little at the top, maybe not. A test fit prior to applying the grille cloth will tell for certain.
Grill frame for 89 - by BrendaAnnD - 07-10-2013, 03:38 AM
RE: Grill frame for 89 - by Ron Ramirez - 07-10-2013, 05:41 AM
RE: Grill frame for 89 - by BrendaAnnD - 07-10-2013, 06:14 AM
RE: Grill frame for 89 - by Arran - 07-10-2013, 07:54 PM
RE: Grill frame for 89 - by BrendaAnnD - 07-10-2013, 08:06 PM
RE: Grill frame for 89 - by Arran - 07-10-2013, 10:12 PM
RE: Grill frame for 89 - by Ron Ramirez - 07-11-2013, 05:51 AM
RE: Grill frame for 89 - by Steve Davis - 07-11-2013, 01:56 PM
RE: Grill frame for 89 - by Arran - 07-11-2013, 09:24 PM
There are currently 9824 online users. [Complete List]
» 2 Member(s) | 9822 Guest(s)
