Model 41-280 "slide Rule" dial
Bill , Do not disassemble your radio dial !!! .I found an intact one locally and already made the part. Thanks again for the offer to scan the part it is much appreciated !!!
Model 41-280 "slide Rule" dial - by bill T - 11-07-2005, 07:50 AM
[No subject] - by Bill Hutchinson - 11-07-2005, 11:31 AM
[No subject] - by bill T - 11-08-2005, 07:50 AM
[No subject] - by bill T - 11-19-2005, 11:43 AM
[No subject] - by Bill Hutchinson - 11-19-2005, 05:35 PM
[No subject] - by bill T - 11-22-2005, 02:52 PM
[No subject] - by Bill Hutchinson - 11-22-2005, 07:58 PM
[No subject] - by bill T - 11-23-2005, 01:07 AM
[No subject] - by Bill Hutchinson - 12-01-2005, 02:50 PM
[No subject] - by bill T - 12-03-2005, 08:01 AM
[No subject] - by Bill Hutchinson - 01-04-2006, 05:52 PM
Philco 91 Tuning Condenser
