It followed me home....is it a keeper???
Arran, once again you are right. Did a little more research and found the radio is actually a model 645. Didn't find it under Coronado, as it's faceplate would lead you to. Came up under Gamble - Skogmo, Inc, the department store based in Minneapolis. And it actually does use the 6G5 tuning eye. The 6N5 in my set must have been quick fix. Hope the higher b+ voltage didn't fry it...it's an engraved base ST. Take care, and thanks, Gary.
RE: It followed me home....is it a keeper??? - by GarySP - 07-10-2013, 03:41 PM
