need help identifying a radio
Hi Crazzywolfie,
You have a 19L that I have never seen anywhere. Notice how it's all cabinet with very little radio inside? The same cabinet was used for a few larger Philco chassis, such as the 14, 16, 17 and 18.
Is there any chance I could get you to send me larger, and better, photos of this radio? Sure, it needs a fair amount of work in its current condition, but it needs to be documented, and I would really like to be able to show photos of an actual set instead of the illustration currently here:
http://www.philcoradio.com/gallery/1933d.htm#f
I will send you an email on this subject with my email address.
By the way, I concur with Philco281989 on the rough value estimate - it may be a rare radio but it is not highly desirable, plus yours does need a fair amount of work.
Thanks in advance!
need help identifying a radio - by crazzywolfie - 07-10-2013, 11:29 AM
RE: need help identifying a radio - by klondike98 - 07-10-2013, 01:42 PM
RE: need help identifying a radio - by Ron Ramirez - 07-10-2013, 07:30 PM
RE: need help identifying a radio - by Arran - 07-10-2013, 08:17 PM
RE: need help identifying a radio - by Arran - 07-10-2013, 09:35 PM
Philco 91 Tuning Condenser
