need help identifying a radio
More straight on, showing the entire radio, plus 3/4 views from the left and right, and a shot of the back showing the entire back would be perfect. 1000 pixels or more in width; larger is better. I sent you an email with my email address to send the pictures to. Thanks!
need help identifying a radio - by crazzywolfie - 07-10-2013, 11:29 AM
RE: need help identifying a radio - by klondike98 - 07-10-2013, 01:42 PM
RE: need help identifying a radio - by Ron Ramirez - 07-10-2013, 07:56 PM
RE: need help identifying a radio - by Arran - 07-10-2013, 08:17 PM
RE: need help identifying a radio - by Arran - 07-10-2013, 09:35 PM
Philco 91 Tuning Condenser
