need help identifying a radio
Orangeville, Ontario.
ok. i will try to get some good pictures of it. my phone is setup to take photos at 2592×1728 pixels so they should be large enough. when i think i have got some good shots i will email them to you.
need help identifying a radio - by crazzywolfie - 07-10-2013, 11:29 AM
RE: need help identifying a radio - by klondike98 - 07-10-2013, 01:42 PM
RE: need help identifying a radio - by Arran - 07-10-2013, 08:17 PM
RE: need help identifying a radio - by crazzywolfie - 07-10-2013, 08:27 PM
RE: need help identifying a radio - by Arran - 07-10-2013, 09:35 PM
There are currently 10532 online users. [Complete List]
» 4 Member(s) | 10528 Guest(s)
AvatarAvatarAvatarAvatar
