Grill frame for 89
Unfortunately, Brenda does not live close to a Michaels or Hobby Lobby, Arran.
I've made my own out of picture matting material (whatever the proper name for the stuff is) from Michaels.
Grill frame for 89 - by BrendaAnnD - 07-10-2013, 03:38 AM
RE: Grill frame for 89 - by Ron Ramirez - 07-10-2013, 05:41 AM
RE: Grill frame for 89 - by BrendaAnnD - 07-10-2013, 06:14 AM
RE: Grill frame for 89 - by Arran - 07-10-2013, 07:54 PM
RE: Grill frame for 89 - by BrendaAnnD - 07-10-2013, 08:06 PM
RE: Grill frame for 89 - by Arran - 07-10-2013, 10:12 PM
RE: Grill frame for 89 - by Ron Ramirez - 07-11-2013, 05:51 AM
RE: Grill frame for 89 - by Steve Davis - 07-11-2013, 01:56 PM
RE: Grill frame for 89 - by Arran - 07-11-2013, 09:24 PM
