Restore a 37-610
Thanks for the advice guys! I think I will just plug away and try to find some knobs on the site Bob provided while periodically checking out eBay and Craigslist.
Is there anyway to find a list of where these meets are that Tab suggested I look into?
Also, I found this grill cloth on RadioDaze http://www.radiodaze.com/product/12906.aspx - is that the right one?
Restore a 37-610 - by deuceaf22 - 07-10-2013, 08:53 PM
RE: Restore a 37-610 - by tab10672 - 07-10-2013, 11:29 PM
RE: Restore a 37-610 - by RadioRandy - 07-11-2013, 02:31 AM
RE: Restore a 37-610 - by Ron Ramirez - 07-11-2013, 05:49 AM
RE: Restore a 37-610 - by klondike98 - 07-11-2013, 07:35 AM
RE: Restore a 37-610 - by deuceaf22 - 07-11-2013, 11:15 AM
RE: Restore a 37-610 - by tab10672 - 07-11-2013, 04:16 PM
There are currently 10037 online users. [Complete List]
» 2 Member(s) | 10035 Guest(s)
