Model 65 alignment
It acts as it should on strong stations but is has no effect on tuning and as for the trimmers there are 3 behind the tuning condenser like the ant. trimmer on an aa5 but 2 of them have a lock nut as if they were not supposed to be adjusted no 4 on the schematic is the only adjustment. One thing i did notice is that the original part values did not match the schematic all resistors were 100 instead of 200 and a couple of the caps were .05 instead of .1 was there a change in production that would have made the new parts i installed as per the schematic a problem? thanks, Todd
Model 65 alignment - by tab10672 - 07-09-2013, 11:29 AM
RE: Model 65 alignment - by 7estatdef - 07-09-2013, 09:03 PM
RE: Model 65 alignment - by tab10672 - 07-09-2013, 11:05 PM
RE: Model 65 alignment - by 7estatdef - 07-10-2013, 07:18 AM
RE: Model 65 alignment - by tab10672 - 07-10-2013, 11:18 PM
RE: Model 65 alignment - by BrendaAnnD - 07-10-2013, 11:24 PM
RE: Model 65 alignment - by tab10672 - 07-10-2013, 11:35 PM
RE: Model 65 alignment - by BrendaAnnD - 07-11-2013, 12:41 AM
RE: Model 65 alignment - by Ron Ramirez - 07-11-2013, 05:47 AM
RE: Model 65 alignment - by tab10672 - 07-11-2013, 03:04 PM
There are currently 4145 online users. [Complete List]
» 1 Member(s) | 4144 Guest(s)
