Hello everyone, new to site.
Thank you for the welcome Terry!
I almost bought a 38-22CS but held out for the 38-7T. I like the cone-centric
tuning a lot. And also the shadow dial too.
Also I have several Philco cathedral radios, a 620 and a 38-9 table model. So I am sure I will need lots of info to get the necessary repairs done.
David
Hello everyone, new to site. - by plymouthrod - 07-11-2013, 03:48 PM
RE: Hello everyone, new to site. - by 7estatdef - 07-11-2013, 08:46 PM
RE: Hello everyone, new to site. - by plymouthrod - 07-11-2013, 09:24 PM
RE: Hello everyone, new to site. - by klondike98 - 07-11-2013, 09:34 PM
RE: Hello everyone, new to site. - by Arran - 07-11-2013, 10:26 PM
RE: Hello everyone, new to site. - by plymouthrod - 07-12-2013, 08:03 AM
There are currently 8844 online users. [Complete List]
» 5 Member(s) | 8839 Guest(s)
AvatarAvatarAvatarAvatar
