Grill frame for 89
Good idea Steve, the cardboard from a cheap three ring binder, that would certainly work, in fact it may be thicker then the cardboard piece he's selling. I wonder just what they do have for craft and stationary stores in Korea? There must be some equivalent?
Grill frame for 89 - by BrendaAnnD - 07-10-2013, 03:38 AM
RE: Grill frame for 89 - by Ron Ramirez - 07-10-2013, 05:41 AM
RE: Grill frame for 89 - by BrendaAnnD - 07-10-2013, 06:14 AM
RE: Grill frame for 89 - by Arran - 07-10-2013, 07:54 PM
RE: Grill frame for 89 - by BrendaAnnD - 07-10-2013, 08:06 PM
RE: Grill frame for 89 - by Arran - 07-10-2013, 10:12 PM
RE: Grill frame for 89 - by Ron Ramirez - 07-11-2013, 05:51 AM
RE: Grill frame for 89 - by Steve Davis - 07-11-2013, 01:56 PM
RE: Grill frame for 89 - by Arran - 07-11-2013, 09:24 PM
There are currently 7074 online users. [Complete List]
» 1 Member(s) | 7073 Guest(s)
