Shadowmeter ?
Well, if we would listen to the OP, the meter is apparently missing. As I recall, there are two differing set ups on Philcos, one with the meter alone supplying B+ to the front end of the receiver and one where it did the same thing but with a resistor in parallel just in case the coil should open and the the front end will still get enough voltage to work. If yours is a receiver that did not have that bypass resistor, I agree with Brenda , should work just fine with a bypass wire or maybe a 1-2K resistor if the B+ looks a little high. If it had that resistor in parallel, you shouldn't need to do anything.
Again, I know nothing!Icon_angel
Jerry
Shadowmeter ? - by Jim Dutridge - 07-11-2013, 02:42 PM
RE: Shadowmeter ? - by BrendaAnnD - 07-11-2013, 03:45 PM
RE: Shadowmeter ? - by Jim Dutridge - 07-11-2013, 04:57 PM
RE: Shadowmeter ? - by Arran - 07-11-2013, 11:45 PM
RE: Shadowmeter ? - by jerryhawthorne - 07-12-2013, 02:31 AM
RE: Shadowmeter ? - by simplex1040 - 07-12-2013, 03:17 PM
RE: Shadowmeter ? - by Chuck Schwark - 07-12-2013, 03:40 PM
RE: Shadowmeter ? - by jerryhawthorne - 07-12-2013, 04:24 PM
RE: Shadowmeter ? - by morzh - 07-12-2013, 07:12 PM
RE: Shadowmeter ? - by Jim Dutridge - 07-12-2013, 07:19 PM
