Installing new V grill cloth
My neighbor finally got his shipment of the new cloth from RadioDaz and it looks really nice. I only wish they would roll it and ship it in a small tube instead of folding it. It's a real pest to get the folding lines out of it.
Jerry
Installing new V grill cloth - by jerryhawthorne - 07-13-2013, 05:34 PM
RE: Installing new V grill cloth - by PhilcoJohn - 07-13-2013, 06:24 PM
RE: Installing new V grill cloth - by klondike98 - 07-13-2013, 08:29 PM
RE: Installing new V grill cloth - by sirwalt - 07-13-2013, 11:54 PM
RE: Installing new V grill cloth - by Ron Ramirez - 07-14-2013, 08:51 AM
RE: Installing new V grill cloth - by klondike98 - 07-14-2013, 10:10 AM
RE: Installing new V grill cloth - by morzh - 07-14-2013, 11:43 AM
RE: Installing new V grill cloth - by sirwalt - 07-14-2013, 06:16 PM
RE: Installing new V grill cloth - by Art Hoch - 07-15-2013, 04:55 PM
RE: Installing new V grill cloth - by Arran - 07-16-2013, 09:23 AM
There are currently 10513 online users. [Complete List]
» 2 Member(s) | 10511 Guest(s)
