Radio Bar 60 B Rebuild
The Model 60 would not have had any rubber in its dial lamp socket originally. Philco did not start using a rubber insulator in its dial lamp sockets until the 1937 model year. Maybe some late 1936 models also - not sure at this time, but definitely 1937 to 1942.
The page Richard refers to on dial lamp socket rebuilding is indeed on my site:
http://www.philcoradio.com/tech/lamps.htm
Radio Bar 60 B Rebuild - by madghost - 02-12-2008, 09:20 AM
[No subject] - by Ron Ramirez - 02-12-2008, 11:18 AM
[No subject] - by rghines1 - 02-12-2008, 11:36 AM
[No subject] - by madghost - 02-13-2008, 10:57 AM
[No subject] - by Ron Ramirez - 02-13-2008, 08:00 PM
[No subject] - by madghost - 02-13-2008, 10:09 PM
[No subject] - by Ron Ramirez - 02-14-2008, 06:38 PM
Philco 91 Tuning Condenser
