Restoring my 37-116. It plays now!
Threads: 562
Cathode bypass caps will not create fire, sure, but they affect the amplifier performance.
RE: Starting on my 37-116 - hit a snag - by morzh - 07-13-2013, 11:22 PM
Users browsing this thread: 41 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 9979 online users. [Complete List] » 3 Member(s) | 9976 Guest(s)
