37-84 whistles
Working on a 37-84 after fighting all of the crap a previous repair person left in it, I went for the power up. all I get is whistles in certain places on the dial that cannot be controlled by the volume control. I am going to peek at the osc coil primary ans see if it is toast as it has been on many others I have read about.
I have rebuilt all bakelite blocks, replaced the filers and replaced out of spec resistors.
anything else?
37-84 whistles - by simplex1040 - 07-14-2013, 04:43 PM
RE: 37-84 whistles - by simplex1040 - 07-14-2013, 05:03 PM
RE: 37-84 whistles - by Ron Ramirez - 07-14-2013, 06:43 PM
RE: 37-84 whistles - by simplex1040 - 07-14-2013, 06:45 PM
RE: 37-84 whistles - by simplex1040 - 07-14-2013, 06:49 PM
RE: 37-84 whistles - by Ron Ramirez - 07-14-2013, 07:03 PM
RE: 37-84 whistles - by simplex1040 - 07-14-2013, 07:26 PM
RE: 37-84 whistles - by exray - 07-14-2013, 08:23 PM
RE: 37-84 whistles - by simplex1040 - 07-14-2013, 08:41 PM
RE: 37-84 whistles - by simplex1040 - 07-14-2013, 09:30 PM
RE: 37-84 whistles - by codefox1 - 07-15-2013, 02:45 PM
RE: 37-84 whistles - by simplex1040 - 08-04-2013, 09:00 PM
There are currently 9998 online users. [Complete List]
» 3 Member(s) | 9995 Guest(s)
