1937-38 Acoustic Clarifiers
Are the clarifiers used in the 1937-116 & 690 the same as the ones in the 1938-116 & 690?? can they be swapped ?
Gene
1937-38 Acoustic Clarifiers - by Gene Pederson - 07-14-2013, 05:38 PM
RE: 1937-38 Acoustic Clarifiers - by Ron Ramirez - 07-14-2013, 07:02 PM
RE: 1937-38 Acoustic Clarifiers - by Arran - 07-14-2013, 09:48 PM
RE: 1937-38 Acoustic Clarifiers - by morzh - 07-14-2013, 09:56 PM
RE: 1937-38 Acoustic Clarifiers - by Arran - 07-14-2013, 10:28 PM
RE: 1937-38 Acoustic Clarifiers - by audiomagnate - 07-15-2013, 01:58 PM
RE: 1937-38 Acoustic Clarifiers - by Ron Ramirez - 07-15-2013, 04:28 PM
RE: 1937-38 Acoustic Clarifiers - by morzh - 07-15-2013, 06:44 PM
RE: 1937-38 Acoustic Clarifiers - by audiomagnate - 07-15-2013, 06:48 PM
RE: 1937-38 Acoustic Clarifiers - by PhilcoJohn - 07-15-2013, 07:57 PM
RE: 1937-38 Acoustic Clarifiers - by Mondial - 07-15-2013, 09:17 PM
Philco 91 Tuning Condenser
