37-84 whistles
OK that may be it I can pick up my transmitter in the house good and it sounds good, any other signal squeals.
37-84 whistles - by simplex1040 - 07-14-2013, 04:43 PM
RE: 37-84 whistles - by simplex1040 - 07-14-2013, 05:03 PM
RE: 37-84 whistles - by Ron Ramirez - 07-14-2013, 06:43 PM
RE: 37-84 whistles - by simplex1040 - 07-14-2013, 06:45 PM
RE: 37-84 whistles - by simplex1040 - 07-14-2013, 06:49 PM
RE: 37-84 whistles - by Ron Ramirez - 07-14-2013, 07:03 PM
RE: 37-84 whistles - by simplex1040 - 07-14-2013, 07:26 PM
RE: 37-84 whistles - by exray - 07-14-2013, 08:23 PM
RE: 37-84 whistles - by simplex1040 - 07-14-2013, 08:41 PM
RE: 37-84 whistles - by simplex1040 - 07-14-2013, 09:30 PM
RE: 37-84 whistles - by codefox1 - 07-15-2013, 02:45 PM
RE: 37-84 whistles - by simplex1040 - 08-04-2013, 09:00 PM
There are currently 8604 online users. [Complete List]
» 2 Member(s) | 8602 Guest(s)
