37-84 whistles
Good deal! Icon_thumbup
Remember, when you attach a longer antenna, that you will need to readjust the regeneration control.
37-84 whistles - by simplex1040 - 07-14-2013, 04:43 PM
RE: 37-84 whistles - by simplex1040 - 07-14-2013, 05:03 PM
RE: 37-84 whistles - by Ron Ramirez - 07-14-2013, 06:43 PM
RE: 37-84 whistles - by simplex1040 - 07-14-2013, 06:45 PM
RE: 37-84 whistles - by simplex1040 - 07-14-2013, 06:49 PM
RE: 37-84 whistles - by Ron Ramirez - 07-14-2013, 07:03 PM
RE: 37-84 whistles - by simplex1040 - 07-14-2013, 07:26 PM
RE: 37-84 whistles - by exray - 07-14-2013, 08:23 PM
RE: 37-84 whistles - by simplex1040 - 07-14-2013, 08:41 PM
RE: 37-84 whistles - by simplex1040 - 07-14-2013, 09:30 PM
RE: 37-84 whistles - by codefox1 - 07-15-2013, 02:45 PM
RE: 37-84 whistles - by simplex1040 - 08-04-2013, 09:00 PM
There are currently 9815 online users. [Complete List]
» 1 Member(s) | 9814 Guest(s)
