Output Trans on 34
The sig gen may not have enough: remember, the output transformer converts tens to a couple of hundred volts to a very few volts, like 3 to 10 maybe.
But...maybe. You don't stand to lose anything by doing it, and it just might work to the degree that you will be able to hear a very quiet tone. Which is all you need.
Output Trans on 34 - by marty - 07-14-2013, 10:08 AM
RE: Output Trans on 34 - by morzh - 07-14-2013, 10:43 AM
RE: Output Trans on 34 - by marty - 07-14-2013, 03:40 PM
RE: Output Trans on 34 - by morzh - 07-14-2013, 08:07 PM
RE: Output Trans on 34 - by marty - 07-14-2013, 10:53 PM
RE: Output Trans on 34 - by morzh - 07-14-2013, 11:04 PM
RE: Output Trans on 34 - by marty - 07-14-2013, 11:09 PM
RE: Output Trans on 34 - by marty - 07-15-2013, 11:30 AM
There are currently 9260 online users. [Complete List]
» 2 Member(s) | 9258 Guest(s)
