1937-38 Acoustic Clarifiers
You do not necessarily have to have back for it to work. Often times the radio was against the wall, so the wall and the narrow space between the radio served as the lossy load, so clarifiers could use that. But even without back the very presense of an anti-resonator tuned to the resonant frequency of the cabinet/speaker system helps somewhat.
1937-38 Acoustic Clarifiers - by Gene Pederson - 07-14-2013, 05:38 PM
RE: 1937-38 Acoustic Clarifiers - by Ron Ramirez - 07-14-2013, 07:02 PM
RE: 1937-38 Acoustic Clarifiers - by Arran - 07-14-2013, 09:48 PM
RE: 1937-38 Acoustic Clarifiers - by morzh - 07-14-2013, 09:56 PM
RE: 1937-38 Acoustic Clarifiers - by Arran - 07-14-2013, 10:28 PM
RE: 1937-38 Acoustic Clarifiers - by audiomagnate - 07-15-2013, 01:58 PM
RE: 1937-38 Acoustic Clarifiers - by Ron Ramirez - 07-15-2013, 04:28 PM
RE: 1937-38 Acoustic Clarifiers - by morzh - 07-15-2013, 06:44 PM
RE: 1937-38 Acoustic Clarifiers - by audiomagnate - 07-15-2013, 06:48 PM
RE: 1937-38 Acoustic Clarifiers - by PhilcoJohn - 07-15-2013, 07:57 PM
RE: 1937-38 Acoustic Clarifiers - by Mondial - 07-15-2013, 09:17 PM
Philco 91 Tuning Condenser
There are currently 4400 online users. [Complete List]
» 1 Member(s) | 4399 Guest(s)
